NetApp Knowledgebase
Why is copy-offload faster between directories or LUNs on the same volume compared to directories or LUNs on separate volumes?
31
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
perf
Last Updated:
Applies to
ONTAP 9
Answer
To copy data inside a volume, ONTAP is using a mechanism that just updates the metadata of the blocks that are to be copied. The physical blocks are not moved.
  • This can not be achieved when the copy is between separate volumes
  • Copy between separate volumes is implemented by moving the physical blocks of data
Additional Information
additionalInformation_text
