NetApp Knowledge Base
Why do network speed mismatches create problems with shallow buffered switches?
709
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
network
Last Updated:
Applies to
  • All NetApp products
  • TCP Communication
  • CIFS, NFS, and iSCSI
Answer
  • Switches often marketed as "Cut-Through" or "Ultra-low latency" switches have shallow port/ASIC buffers.
  • A shallow buffer switch is considered shallow when the buffer is less than Bandwidth Delay Product (BDP).
  • When translating speeds from a faster medium to a slower (100Gb/s to 10Gb/s for example, or 10Gb/s to 1Gb/s), buffering is required but insufficient to handle these link speed translations.
  • Packet loss degrades performance due to how TCP operates.
  • To resolve this condition:
    • Ensure both the sender and receiver have equal speeds, and if bonded in a LACP bond, equal amounts of ports in the bond.
    • Also, ensure the network path is not slower than sender or receiver.
    • If multiple senders feed into one receiver (multiple clients to a single storage system for example), more bond links may be needed between connecting switches.
    • Open a ticket with the network vendor if more assistance is needed to resolve the issue.
Additional Information
  • Bandwidth Delay Product
    • The product of a data link's capacity (in bits per second) and its round-trip delay time (in seconds). The result, an amount of data measured in bits (or bytes), is equivalent to the maximum amount of data on the network circuit at any given time, i.e., data that has been transmitted but not yet acknowledged.
    • The bandwidth-delay product can be estimated by multiplying the ports link speed (in Bits per second) divided by 10, with the round trip time under load across the switch - typically in the order of around 1 millisecond: 40 Gbps / 10 ~= 4 GB/sec * 0.001 sec = 4.2 MB buffer memory. The round trip time includes not only the propagation delay of the wires, and the switch latency, but also any buffering within the switch, the host or the storage system while exchanging traffic. A switch that switches between different link speeds should provide buffer memory in this range on the participating ports.
  • In Cisco switches, this will be designed on the show interface command as input discards or output discards. For example:
    • Ethernet1/15 is up
       Dedicated Interface
        Hardware: 1000/10000 Ethernet, address: (ommitted)
        Description: Cluster Node 15
        MTU 1500 bytes, BW 10000000 Kbit,, BW 10000000 Kbit, DLY 10 usec
        reliability 255/255, txload 1/255, rxload 1/255
        Encapsulation ARPA, medium is broadcast
        Port mode is access
        full-duplex, 10 Gb/s, media type is 10G
        Beacon is turned off
        Input flow-control is off, output flow-control is off
        Rate mode is dedicated
        Switchport monitor is off
        EtherType is 0x8100
        Last link flapped 1week(s) 4day(s)
        Last clearing of "show interface" counters 00:48:16
        42 interface resets
        30 seconds input rate 1028568 bits/sec, 504 packets/sec
        30 seconds output rate 6245824 bits/sec, 856 packets/sec
        Load-Interval #2: 5 minute (300 seconds)
          input rate 919.41 Kbps, 417 pps; output rate 5.89 Mbps, 742 pps
        RX
          137789441038 unicast packets  1137881 multicast packets  168522 broadcast packets
          137790747441 input packets  398042347738746 bytes
          44682377059 jumbo packets  0 storm suppression bytes
          0 runts  0 giants  0 CRC  0 no buffer
          0 input error  0 short frame  0 overrun   0 underrun  0 ignored
          0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
          0 input with dribble  465262 input discard
      <-------465k discards in 48 minutes, 16 seconds, or ~161 per second average
          0 Rx pause
        TX
          181286566439 unicast packets  59885021 multicast packets  3752105 broadcast packets
          181350203565 output packets  534820871246236 bytes
          54004919525 jumbo packets
          0 output error  0 collision  0 deferred  0 late collision
          0 lost carrier  0 no carrier  0 babble 0 output discard
          0 Tx pause
