NetApp Knowledge Base
Which ports need to be open for CIFS between ONTAP systems and Domain Controllers?
10,351
Visibility:
Votes:
17
Category:
ontap-9
Specialty:
nas
Last Updated:
Applies to
  • ONTAP 9
  • Data ONTAP 8
  • CIFS/SMB
Answer
For a proper communication between ONTAP systems and Windows Domain Controllers the following ports must be open on the firewall
ONTAP System Direction Domain Controller
ANY  ->
SMB over IP (TCP:445)
DNS (TCP and UDP: 53)
LDAP (TCP: 389)
LDAPS (TCP: 636) (optional: only if LDAPS enabled)
Kerberos (TCP and UDP: 88)
Kpasswd (TCP and UDP: 464)
SMB over IP (TCP:445) (optional: needed to access the shares)
<- ANY
Additional Information
ONTAP can use any IP on the SVM for outgoing traffic, the choice of which interface will be used is based on routing to the destination and not which protocol has been enabled on the interface itself.
