When using Onboard Key Management (OKM): VEKs are not listed for some nodes when performing a key query
Applies to
- ONTAP 9.6
Issue
VEKs are not listed under some nodes when performing "security key-manager key query
Cluster::*> key-manager key query
(security key-manager key query)
Vserver: Cluster
Key Manager: onboard
Node: Cluster-01
Key Server: ""
Key Tag Key Type Restored
Cluster-01 NSE-AK true
Key ID: 000000000000000002000000000001003260fcee69xxxx88155e8f9511a75680000000000000000
Key ID: 00000000000000000200000000000100354a30c9xxxx1b4ea18d772a94dc398d0000000000000000
Cluster-01 SVM-KEK true
Key ID: 00000000000000000200000000000a002c38fab416e3d9xxx8c0876576160ff0000000000000000
Key ID: 00000000000000000200000000000a008a2aafe553axxxxc2f1d1429014c35c70000000000000000
Vserver: Cluster
Node: Cluster-02
Key Server: ""
Cluster-02 NSE-AK true
Key ID: 000000000000000002000000000001003260fcee69xxxxd88155e8f9511a75680000000000000000
SVM1 VEK true
Key ID: 00000000000000000200000000000500950bdf38a251b7xxxxac5acae751d5aa0000000000000000
SVM1 VEK true
Key ID: 00000000000000000200000000000500a3896a2b6ab5xxxx6387c9b52c31005c0000000000000000
Cluster-02 SVM-KEK true
Key ID: 00000000000000000200000000000a002c38fab416e3d9xxxx8c0876576160ff0000000000000000
10 entries were displayed.
If any listed keys have "false" in the "Restored" column, run the "security key-manager external restore" command to restore the
keys that are stored on an external key server and run the "security key-manager onboard sync" command to synchronize the keys
that are part of the onboard key hierarchy.
Observe the following keys are not listed under node: Cluster-01:
SVM1 VEK true
SVM1 VEK true
