When is a multi-hop upgrade applicable in ONTAP 9?
Applies to
- All ONTAP 9 releases
- Upgrades
Answer
Beginning in ONTAP 9.7, multi-hop upgrades of Long term releases are supported, which means you can perform a direct upgrade from 9.3 to 9.7.
- The version of ONTAP that you can upgrade or downgrade varies based on the version of ONTAP currently running on your cluster.
Upgrade Paths
- For the latest and most accurate information please refer to the guide What version of ONTAP can I upgrade to?
Reverts
- For the latest and most accurate information please refer to the guide ONTAP Revert paths.
- Reverting is a single hop operation. meaning you must revert one version at a time until you reach your desired version.
Example
- You multi-hop upgrade from 9.3 to 9.7
- In a rare situation you may have to revert
- then you must revert from 9.7 to 9.6, then to 9.5 until you reach 9.3
- You may also decide to remain in 9.6 or 9.5 depending on the issue. At this point you should have a Support ticket open for assistance
- Do I need technical support to revert? If you require assistance please contact NetApp Technical Support and reference this article
Additional Information
- Additionally, starting with ONTAP 9.6, all feature releases will receive 5 years of software version support and will be designated as LTS.
- For more information, see the Long Term Service (LTS) Definition
- Refer to the ONTAP Software Version Support Table for the ONTAP Software Version Support Policy.
- Preparing to revert ONTAP clusters
SU2 : Recommended ONTAP releases on the NetApp Support Site
