NetApp Knowledge Base
What triggers an update to Disk, Shelf, or ACP firmware in Data ONTAP 8 7-Mode?
851
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
7dot
Last Updated:
Applies to
  • Data ONTAP 8
Answer
Disk Firmware
Disk Firmware will be updated in one of the following three ways:
In the Background
This occurs when the following conditions are met:
  • options raid.background_disk_fw_update.enable is on
    -or-
    options raid.disk.background_fw_update.raid4.enable is on (where applicable)
  • Newer firmware for the disks present is placed in the /etc/disk_fw directory.
When manually triggered
  • options raid.background_disk_fw_update.enable is off
    -or-
    options raid.disk.background_fw_update.raid4.enable is off (where applicable)
  • The disk_fw_update command is issued.
Upon next reboot
    -or-
  • Newer firmware for disks present is placed in the /etc/disk_fw directory
  • The system is rebooted.
Shelf Firmware
Shelf Firmware is updated in one of the following three ways:
Note: There are some concerns specific to the AT-FCX modules which is addressed on each shelf FW download page.
  • Newer firmware for the shelf modules present is placed in the /etc/shelf_fw directory.
-and-
  • The following commands are issued:
    • priv set advanced
    • storage download shelf
       -or-
      storage download shelf adapter_name
    • priv set
Upon the next reboot
This occurs when both the following conditions are met:
  • The controller is rebooted.
Upon certain events being encountered
-and-
  • One of the following events occur:
    • The cf giveback command is issued
    • New disk drives are inserted
    • New shelf modules are inserted
    • A-SAS shelf is hot-added
ACP Firmware
ACP Firmware is updated in one of the following two ways:
In the background
This occurs when the following condition is met:
Newer firmware for the ACP is placed in the /etc/acpp_fw directory.
Note: No other action is required - Data ONTAP polls this directory periodically.
  • Newer firmware for the ACP is placed in the /etc/acpp_fw directory.
    • priv set advanced
    • storage download acp
    • priv set
For complete information on all the firmware updates, see the Upgrade Guide for the version of Data ONTAP being used.
Additional Information
additionalInformation_text
