NetApp Knowledge Base
What kind of management activies are audited by ONTAP and available in AutoSupport logs?
157
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
nas
Last Updated:
Applies to
  • ONTAP
  • AutoSupport enabled systems
Answer
As per the default settings, the management activities audited operations that are found in AutoSupport logs must be executed in the following ways:
  • Using ONTAP CLI
  • Using ONTAP System Manager
  • Using API calls
If a system is managed in some other way, then the audit may or may not happen. In such cases, to ensure successful auditing, vserver auditing needs to be enabled.
