NetApp Knowledge Base
What is volume autosize in Data ONTAP?
7,336
Visibility:
Votes:
5
Category:
data-ontap-8
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9
  • Data ONTAP 8
  • Data ONTAP 8 7-Mode
  • Data ONTAP 7 and earlier
  • Cloud Volume Ontap
Answer
What does volume autosize do?
  • Volume autosize is a policy-based space-management feature in Data ONTAP that allows the volume to grow by an increment if the volume is nearly full.
  • The nearly full threshold is defined by the flag wafl_reclaim_threshold.
  • When a write is sent to the node that is larger than available space, Data ONTAP will try to write as much as possible before failing the write with a volume full message.
    • During the next check, the volume will grow by increments until it has reached the minimum free space threshold.
    • This means that autosize is best described as 'grow on use,' rather than 'grow on demand,' a distinction that should be remembered when planning thresholds and grow increments.
  • Note that volume autosize does not infinitely grow the volume.
    • The volume will grow until it reaches the maximum autosize value and then no more space will be allocated.
The syntax for enabling volume autosize is as follows:
Clustered Data ONTAP/ONTAP 9:
::> volume modify -vserver <vserver_name> -volume <volume_name> -autosize
-autosize-increment                -autosize-increment-percent
-autosize-grow-threshold-percent   -autosize-shrink-threshold-percent
-autosize-mode                     -autosize
-autosize-reset                    -antivirus-on-access-policy
Note: Starting in ONTAP 9, -autosize-increment is unavailable, as this value is dynamically determined by ONTAP.
For more details on above parameters refer to the documentation for the `volume modify` command
Data ONTAP 7:
> vol autosize  [-m [k|m|g|t]]
               [-i [k|m|g|t]]
              [ on | off | reset ]
-m option sets the maximum size a volume is permitted to grow. Default setting is 120% of volume size at the time of creation
-i option defines the increment by which a volume is grown every time the volume is full. Default setting is 5% of volume size at the time of creation
on enables the feature
off disables the feature
reset resets the settings to default value.
Choosing reclaim policies:
In order to reclaim space which is determined by defining policies, with the use of the try_first volume option. The try_first volume option determines whether:
  • Snapshot autodelete would be attempted first.
  • Or volume autosize would be attempted first.
The possible try_first values are:
  • snap_delete
  • volume_grow
