If you missed the pre-registration for NetApp MS Azure AD B2C Go Live, when you log in, the new login prompt will offer the option to register. Please note that access to your NetApp data may take up to 1 hour. Need assistance? Complete this form and select “Registration Issue” as the Feedback Category.
NetApp Knowledge Base
What is the impact of disabling "-enable-ejukebox" and "-v3-connection-drop" on NFS operations?
470
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
nfs
Last Updated:
Applies to
ONTAP 9
Answer
  • When "Enable NFSv3 EJUKEBOX error" (-ejukebox-enable) is true and "Enable the Dropping of a Connection When an NFSv3 Request is Dropped" (-v3-connection-drop) is enabled, ONTAP responds to the RPC request with NFS3ERR_JUKEBOX, and the client retries the RPC request with a new RPC transaction ID after a short wait
    • In rare cases where ONTAP is unable to respond, the NFS server may close the connection instead of responding with NFS3ERR_JUKEBOX
  • When "Enable NFSv3 EJUKEBOX error" (-ejukebox-enable) is false and "Enable the Dropping of a Connection When an NFSv3 Request is Dropped" (-v3-connection-drop) is enabled, ONTAP drops the response and closes the connection, and the client reconnects after a few seconds to retry the RPC request
  • When "Enable NFSv3 EJUKEBOX error" (-ejukebox-enable) is false and "Enable the Dropping of a Connection When an NFSv3 Request is Dropped" (-v3-connection-drop) is disable, ONTAP drops the response but does not close the connection, causing the client to timeout the RPC request and retransmit it
    • Note: Depending on the client, this may take a few minutes
Additional Information
  • To view the current values:
cluster1::> set -privilege advanced
cluster1::*> vserver nfs show -vserver <SVM> -fields enable-ejukebox,v3-connection-drop
cluster1::*> set admin
