Coming soon...New Support-Specific categorization of Knowledge Articles in the NetApp Knowledge Base site to improve navigation, searchability and your self-service journey.
What is Cluster HA and how is Epsilon utilized to maintain RDB Quorum?
3,017
Visibility:
Votes:
1
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9
  • Cluster HA (2 node cluster)
Answer
What is RDB Quorum?
RDB Quorum is a precondition for a fully functioning cluster
  • Configurations that have greater than 2 nodes in the cluster, the entire cluster maintains quorum using a voting mechanism where each node has a vote that decides which node will maintain the master copy (read/write) of the replicated databases (also known as the RDB Master)
  • When a cluster is in quorum, a simple majority of nodes are healthy and can communicate with each other
  • When quorum is lost, the cluster loses the ability to accomplish normal cluster operations
What is epsilon?
Epsilon is a tie breaker
  • Because there is the possibility of a tie in a cluster that has an even number of nodes, one node has an extra fractional voting weight called epsilon
  • If the connectivity between two equal portions of a large cluster fails, the group of nodes containing epsilon maintains quorum, assuming that all of the nodes are healthy
What is Cluster HA?
Cluster HA allows continuous monitoring of a 2 node Cluster's state
  • A 2 node cluster presents some unique challenges for maintaining quorum
  • 2 node clusters use cluster HA, in which neither node holds epsilon
  • Instead, both nodes are continuously polled to ensure that if one node fails, the other has full read-write access to data, as well as access to logical interfaces and management functions
  • Quorum is maintained by a successful takeover
Check Active IQ if this impacts your systems
Scan to view the article on your device
