NetApp Knowledgebase
What happens if volume is converted to FlexGroup while volume efficiency is in progress?
50
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9
  • FlexGroup
Answer
Volume efficiency stops with the following message.
Example:
Warning: An efficiency operation is running on volume "vol1" in Vserver "svm1".  It is recommended to wait until the efficiency
         operation completes before converting the volume to a FlexGroup.  Use the "volume efficiency show -vserver svm1 -volume
         vol1" command to monitor the status of the efficiency operation.
Do you want to continue? {y|n}:
Additional Information
Add your text here.
