Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
NetApp Knowledge Base
What happens if volume is converted to FlexGroup while volume efficiency is in progress?
142
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9
  • FlexGroup
Answer
Volume efficiency stops with the following message.
Example:
Warning: An efficiency operation is running on volume "vol1" in Vserver "svm1".  It is recommended to wait until the efficiency
         operation completes before converting the volume to a FlexGroup.  Use the "volume efficiency show -vserver svm1 -volume
         vol1" command to monitor the status of the efficiency operation.
Do you want to continue? {y|n}:
Additional Information
Add your text here.
Scan to view the article on your device
