What are the effects of options ip.ping_throttle.drop_level 0 on system environment?
Applies to
- Data ONTAP 8 7-Mode
- ONTAP 9
Answer
The ping throttling mechanism was introduced to mitigate risks from denial of service attacks based on the ICMP protocol. The existing ping throttling mechanism uses the value stored in the option ip.ping_throttle.drop_level
option to obtain a threshold of packets to accept before dropping packets, in a one second interval. NetApp does not currently have a recommended value to set ip.ping_throttle.drop_level
. The default value is 150. The value can be increased to a higher value.
The option ip.ping_throttle.drop_level
setting is not as per client; however, it is for all clients. The max limit is 4294967295.
The reason that NetApp does not recommend any value in environments with many CIFS clients because a threshold exceeds easily. As a result, CIFS clients experience temporary to persistent unavailability of the appliance. Set ip.ping_throttle.drop_level
option between 50 to 150 and increase if issue arises.
To allow clients to send more than 16 packets per second, disable ping throttling. Run the following command to disable this option:
After ONTAP 9.3+, the node shell command was deprecated for this new clustersell option:
::> network tuning icmp
Additional Information
Related links:
- For more information about ping throttling, see page 148 of Data ONTAP 8.2 Network Management Guide.
- For more information about this feature go to MAN PAGE: network tuning icmp modify.
