NetApp Knowledge Base
Web application is slow and unusable on ONTAP Select with Fabric Pool
80
Visibility:
Votes:
0
Category:
ontap-select
Specialty:
perf
Last Updated:
Applies to
  • ONTAP Select
  • FabricPool
Issue
  • Fabricpool reads [GET] operations are the most impacting.
  • Failed GET operations seen
Cluster::> storage aggregate object-store profiler show
Object store config name: netapp-s3
Node name: netapp-s1n1
Op      Size       Total     Failed             Latency(ms)   Throughput
                                        min       max  avg
PUT     4MB        2129      0          211     6262      1428      139.4MB
GET     4KB        538       538       10051     16835     14310     0B
GET     8KB        503       503       10005     17637     14791     0B
GET     32KB       510       510       10530     16098     13661     0B
GET     256KB      561       561       10048     16152     13613     0B
  • The Latency builds up over time and suddenly drops and restarts again and make the applications time out and fail.
New to NetApp?
Scan to view the article on your device
