Vscan engine connects only to one node, other nodes fail with 'remote-closed'
Applies to
- ONTAP AV Connector
- ONTAP 9
- All Antivirus solutions
Issue
- After starting the AV Connector service, the vscan engine is only connecting to a single node in a cluster. The connected node may change after a reboot of the service.
Cluster01::> vserver vscan connection-status show-all -vserver SVM01
- The above command will show the disconnection reason as 'remote-closed', however while running a TEST on ONTAP AV connector UI from the AV server the test finishes successfully.
