Volume encryption conversion (Error: command failed: Failed to start conversion on volume "vol10" in Vserver "svm10". Reason: Node "" is not reachable)
Applies to
- NVE
- ONTAP 9.3
- headswap/motherboard replacement is in progress
Issue
- Not able to convert plain text volume to NVE.
cluster01::*> volume encryption conversion start -vserver svm10 -volume vol10
Error: command failed: Failed to start conversion on volume "vol10" in Vserver "svm10 ". Reason: Node "" is not reachable. Creation of the first encrypted volume in a failover grouprequires encryption resources to be allocated on all nodes in the failover group. Make sure all nodes in the failover group are healthy and then retry the command.
