Volume creation failed with "Operation is disallowed" error
Applies to
- ONTAP 8
- ONTAP 9
Issue
Attempt to create a new volume fails with any of the following errors:
Error: command failed: [Job 706] Job failed: Failed to create the volume on node "cluster-01". Reason: Operation is disallowed on an aggregate which is not home.
... error creating volume: API status: failed, Reason: Failed to create the volume on node \"volume-01\". Reason: Operation is disallowed on an aggregate which is not home. , Code: 13130] (will retry upon resync)" ...
