Upgrade fails due to reason: volume not found
Applies to
- ONTAP
Issue
Upgrade fails with the following message:
Node: Netapp-01 Status:
aborted
Status Message: The upgrade aborted in the "post-apps" phase on task "volume_uuid table quota state and security-style upgrade/revert task". Contact support personnel for the upgrade repair procedure.
Vers Phase Status Upgrade Phase Status Message
1100 pre-root applied No upgrade is required for this phase.
1100 pre-apps applied Upgrade successful.
1100 post-apps applied Upgrade successful.
1400 pre-root applied No upgrade is required for this phase.
1400 pre-apps applied Upgrade successful.
1400 post-apps aborted Failed to get quota attributes for volume "New_Anthem" in Vserver "Tree_House". Reason: Volume not found.
