NetApp Knowledge Base
Upgrade fails due to reason: volume not found
186
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP
Issue
Upgrade fails with the following message:
Node: Netapp-01                                  Status:
                                                              aborted
Status Message: The upgrade aborted in the "post-apps" phase on task "volume_uuid table quota state and security-style upgrade/revert task". Contact support personnel for the upgrade repair procedure.
Vers Phase      Status   Upgrade Phase Status Message
1100 pre-root   applied  No upgrade is required for this phase.
1100 pre-apps   applied  Upgrade successful.
1100 post-apps  applied  Upgrade successful.
1400 pre-root   applied  No upgrade is required for this phase.
1400 pre-apps   applied  Upgrade successful.
1400 post-apps  aborted  Failed to get quota attributes for volume "New_Anthem" in Vserver "Tree_House". Reason: Volume not found.
New to NetApp?
