Upgrade failing after MotherBoard replacement
Applies to
ONTAP 9.5
Issue
After running the command : cluster image resume-update, the upgrade doesn't progress.
cluster::*> cluster image show-update-log
Trans
Phase Transaction Id Component Id Time Stamp Status
package- cleanup- 4
cluster-01 2/18/2020 completed
management package 16:12:38
package- cleanup- 5
cluster-02 2/18/2020 completed
package- process-
18 cluster-01 6/17/2021 completed
management package 09:50:41
package-
synch-image 19 cluster-02 6/17/2021 failed
management 09:51:03
validation
initialize 20 MUM 7/28/2021 paused-on-error
11:15:26
Details: Error: Internal error. Initialization failed, Action: Verify that
all nodes are healthy using the "cluster
show" command, then try
the command again.
validation mount-image 21 cluster-01 7/28/2021
paused-on-error
11:15:26
