NetApp Response to Russia-Ukraine Cyber Threat
In response to the recent rise in cyber threat due to the Russian-Ukraine crisis, NetApp is actively monitoring the global security intelligence and updating our cybersecurity measures. We follow U.S. Federal Government guidance and remain on high alert. Customers are encouraged to monitor the Cybersecurity and Infrastructure Security (CISA) website for new information as it develops and remain on high alert.
NetApp Knowledge Base
Upgrade failed with Read-write transaction is open
78
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9.7
  • ONTAP Upgrade
Issue
  • ONTAP upgrade did not finish
  • The nodes did upgrade to new ONTAP version
  • Cluster version still shows previous ONTAP version
  • ANDU shows "Upgrade aborted"
  • Not all upgrade tasks are completed
Cluster::*> upgrade-revert show-task-status -node Node01
  (system node upgrade-revert show-task-status)
Node         Vers Phase     ID  Proc   Status     Description
Node01     1000  pre-apps 1019 mgwd  applied    ASUP Upgrade/Revert Task
Node01     1000  pre-apps 1027 mgwd  applied    Remove wsman Web Service Upgrade/Revert Task
Node01     1000 post-apps 1001 mgwd  applied    Upgrade/Revert ipsec
Node01     1000 post-apps 1002 mgwd  applied    Support for Flexgroups in an MCC configuration
Node01     1000 post-apps 1003 mgwd  aborted    Upgrade and Revert task for Secd MDB Caching
Node01     1000 post-apps 1005 vifmgr prepared  Upgrade to network port sharing
Node01     1000 post-apps 1006 mgwd  prepared   QoS VR Upgrade Revert
Node01     1000 post-apps 1007 mgwd  prepared   Template Upgrade/Revert Task
Node01     1000 post-apps 1008 mgwd  prepared   Upgrade_Revert of 9.6.0 CP_Crypt Features
Node01     1000 post-apps 1009 vifmgr prepared  Upgrade to Peer Uuid
Node01     1000 post-apps 1010 mgwd  prepared   Predefined_roles_update_upgrade
Node01     1000 post-apps 1011 mgwd  prepared   Obsolete flexgroup capability
  • Mgwd logs error:
mgwd 00000023.0000bb06 000067a2 Tue Jun 16 2020 09:18:19 GMT  [mana0121: kern_mgwd: WARNING] A [src/rdb/TM.cc 3773 (0x82d3aad00)]: _coord_startTxn: RW-transaction TID <93,129,129> held by client 1000 for 165 seconds (created: 2487s, now: 2652s, deadline: 6087s) (label 'CM RDB Initialization Callback').
mgwd 00000018.00002e54 000024cf Tue Jun 16 2020 09:18:19 GMT  [mana0120: kern_mgwd: WARNING] 0x82e1eaf00: 0: ERR: rdb_tran_glue: create: tid=0x82e1eaf00 failed to create transaction for label='CIFS Cache Enable': RW_TXN_EXISTS
mgwd 00000018.00002e55 000024cf Tue Jun 16 2020 09:18:19 GMT  [mana0120: kern_mgwd: WARNING] 0x82e1eaf00: 0: ERR: MGWD::SECD_MDB_CACHE_UPGRADE_REVERT: src/tables/cifs/cache/cache_upgrade_revert.cc:78:upgradeCommit Failed to create transaction. Error: Read-write transaction is open
mgwd 00000018.00002e56 000024cf Tue Jun 16 2020 09:18:19 GMT  [mana0120: kern_mgwd: WARNING] 0x82e1eaf00: 0: INFO: upgrade_revert: Upgrade of row [1000,post-apps,1003,mgwd] failed. Retrying. Reason: Read-write transaction is open.
mgwd 00000018.00002e57 000024cf Tue Jun 16 2020 09:18:19 GMT  [mana0120: kern_mgwd: WARNING] Notice: Upgrade of row [1000,post-apps,1003,mgwd] failed. Retrying. Reason: Read-write transaction is open.
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
