NetApp Knowledge Base
Unable to convert Flexvol volume to Flexgroup without disabling SMB1
369
Visibility:
Votes:
1
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9
  • FlexVol conversion to FlexGroup
Issue
The following error is received:
Cluster::*> volume conversion start -vserver SVM -volume VOL -foreground true
Error: command failed: Cannot convert volume "VOL" in Vserver "SVM" to a FlexGroup. Correct the following issues and retry the command:
* SMB1 is enabled on Vserver "SVM". Use the 'vserver cifs options modify -smb1-enabled false-vserver SVM' command to disable SMB1.
New to NetApp?
