NetApp Knowledge Base
Troubleshooting Connectivity or Reachability issues (Clustered Data ONTAP) in 7MTT
488
Visibility:
Votes:
0
Category:
7-mode-transition-tool
Specialty:
core
Last Updated:
Applies to
  • 7MTT
  • Data ONTAP 8 7-Mode
  • Clustered Data ONTAP
Issue
  • Symptom 1
Transition operation fails with the following blocking error:
01032: Communication problem occurred. [ Error ]
> Timeout occurred while communicating with Cluster-Mode storage system '<IP Address >'.
> CORRECTIVE-ACTION: Check your network configuration, correct the problem and re-run the operations.
  • Symptom 2
Wizard fails with the following error while providing cluster details:
Step: Select target cluster
Enter the FQDN or management IP address of the cluster: <IP Address >
Enter the administrative user-name for the cluster <IP Address > [admin]:
Enter the password for 'admin@<IP Address >':
ERROR: Host '<IP Address >' timed out.
  • Symptom 3
7-Mode Transition Tool>transition credentials add -h <IP Address > -u admin
Enter password for 'admin@<IP Address >':
Error (31009) : Host '<IP Address >' timed out .
New to NetApp?
Scan to view the article on your device
