Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
NetApp Knowledge Base
Takeover impossible and NVRAM log not synchronized in CVO as interconnect was down
2,874
Visibility:
Votes:
1
Category:
cloud-volumes-ontap-cvo
Specialty:
cloud
Last Updated:
Applies to
  • Cloud Volumes ONTAP (CVO)
  • Microsoft Azure
Issue
  • Cluster Interconnect is down
  • e0c port is with no carrier status
Example:
Cluster01::> node run -node * -command ifconfig
        e0c: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=8051b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,TSO4,LRO,LINKSTATE>
        ether 00:0d:3a:6c:28:38
        hwaddr 00:0d:3a:6c:28:38
        inet X.X.X.X netmask 0xffffff00 broadcast 10.196.6.255 Services: 0x00000180 Vserver ID: -5
        media: Ethernet autoselect <full-duplex,rxpause,txpause>
        status: no carrier
cluster01::> storage failover show -fields interconnect-links ,interconnect-up, interconnect-type
node               interconnect-up interconnect-links        interconnect-type
cluster01-01         false           RDMA Interconnect is down iWARP
cluster01-02         false           RDMA Interconnect is down iWARP
2 entries were displayed.
New to NetApp?
Scan to view the article on your device
