NetApp Knowledge Base
System Manager reports "The partner node details were not found for the node" during Initialize Storage System process
1,525
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9
  • ONTAP System Manager (OSM) new cluster WIZARD
Issue
  • After entering initial information for a new ONTAP cluster setup and browsing to System Manager via the node management IP address, only one node is seen
  • the HA partner is not seen, and the following error is presented in the Initialize Storage System section:
The partner node details were not found for the node with the following serial number: . If all the nodes were not found, then check the node connections, reload the cluster setup wizard, and then try to set up the cluster again.
New to NetApp?
