NetApp Knowledge Base
SyncMirror error: Current disk pool assignments do not guarantee fault isolation for aggregates mirrored with SyncMirror
184
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • Local Sync Mirror
  • Advanced Disk Partitioning (ADP)
Issue
Local SyncMirror creation fails with an error as below.
aggr mirror -aggregate <aggregate> -mirror-partitionlist <partition_list> -simulate true
Error: command failed: Aggregate mirroring would fail for aggregate "<aggregate>" on node "<node>". Reason: Current disk pool assignments do not guarantee fault isolation for aggregates mirrored with SyncMirror. Other disks in the loop are in a different pool than disks: "disk_id", "disk_id". Use "disk show -v" to view and "disk assign" to change the disk pool assignments.
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
