Stale shelf data reported per storage shelf show command in ONTAP
Applies to
- ONTAP 9
- AFF/FAS Model
- Disk Shelf
Issue
- The disk shelves can be identified via
storage disk show
orsysconfig -a
command. The storage shelf show
command doesn't show proper information about the shelves.- The newly added disk shelves may not be reported or old disk shelves information(stale entry) may be seen in the outputs.
CLUSTER::> storage shelf show
Module Operational
Shelf Name Shelf ID Serial Number Model Type Status
1.21 21 SHJSG1606000235 DS4246 IOM6 Normal
1.22 22 SHFFG1905000251 DS2246 IOM6 Normal
1.23 23 SHFFG1905000255 DS2246 IOM6 Normal
2.11 11 SHFFG1606000022 DS2246 IOM6 Normal
2.12 12 SHFFG1609000428 DS2246 IOM6 Normal
2.13 13 SHFFG1609000380 DS2246 IOM6 Normal
2.14 14 SHFFG1606000268 DS2246 IOM6 Normal
3.44 44 SHFFG1748000121 DS2246 IOM6 Error (Stale Entry)
