Space is not freed in ONTAP
Applies to
- ONTAP 9.5
- ONTAP 9.5P1
- ONTAP 9.5P2
- Space reclamation
Issue
- Volumes do not reclaim freed space, which can lead to space issues such as full volumes and/or aggregates.
- To confirm, run the following command several times over the span of a few hours:
- The relevant scanner should run once the footprint percent exceeds 2. If the same volumes are shown and the percentage does not decrease, then the volume is experiencing the issue.
- Note: this issue only affects a limited number of releases of ONTAP 9.5
