SP HW Assist - Fail to bind UDP Socket in ONTAP 9
Applies to
- ONTAP 9
- SP
- BMC
- AFF systems
- FAS systems
Issue
After performing an SP update including updating the Internal switch hwassist fails to connect to its partner
- EMS
Cluster-1b ERROR cf.hwassist.missedKeepAlive: HW-assisted takeover missing keep-alive messages from HA partner (Cluster-1a).
- Command Line
Cluster::> storage failover hwassist show Node ----------------- Cluster-1a Partner: Cluster-1b Hwassist Enabled: true Hwassist IP: 10.4.17.224 Hwassist Port: 4444 Monitor Status: inactive Inactive Reason: Fail to bind UDP socket. Corrective Action: Run 'storage failover modify -hwassist-partner-ip <Cluster-1a's node management IP> -node Cluster-1b' and/or run 'storage failover modify -hwassist-partner-port <Cluster-1a's UDP port> -node Cluster-1b' Keep-Alive Status: - Cluster-1b Partner: Cluster-1a Hwassist Enabled: true Hwassist IP: 10.4.17.225 Hwassist Port: 4444 Monitor Status: inactive Inactive Reason: Fail to bind UDP socket. Corrective Action: Run 'storage failover modify -hwassist-partner-ip <Cluster-1b's node management IP> -node Cluster-1a' and/or run 'storage failover modify -hwassist-partner-port <Cluster-1b's UDP port> -node Cluster-1a' Keep-Alive Status: - 2 entries were displayed.
