RSA Key Length of 4096 is not supported in ONTAP when FIPS is enabled
Applies to
ONTAP 9.10 and earlier
Issue
Installing or creating a certificate with RSA key length of 4096 fails with error:
Error: command failed: Specified key size is not supported in FIPS mode
Example:
Cluster::*> cert create -common-name test -type client -size ?
(security certificate create)
2048
3072
4096
Cluster::*> cert create -common-name test -type client -size 4096
