Performance Archives: Performance first failure data collection for Clustered Data ONTAP 8.3 and later
Applies to
- ONTAP Select
- Clustered Data ONTAP 8.3
- ONTAP 9
Answer
- What is a Performance Archive?
- Beginning with clustered Data ONTAP 8.3, performance content is collected and stored ('archived') on every system by default.
- This content is built on top of new functionality in Data ONTAP, which automatically stores Quality of Service performance statistics on a per-volume basis for diagnostic purposes for up to 28 days on each clustered Data ONTAP node.
- Using the AutoSupport(tm) infrastructure, a Performance Archive can be created and uploaded to NetApp.
- How do I upload a Performance Archive?
- Verify if Performance Archive is enabled
::> set diagnostic
::*> statistics archive config show
verify field:
Is the Performance Archive Enabled?: true
if false, enable it by running the following command
::*> statistics archive config modify -is-enabled true
Note: EMS events will also report the following message when the Performance Archive is disabled
::*> event log show -event perf*
Time Node Severity Event
INFORMATIONAL perf.ccma.off: Performance archiver is not enabled.
- Performance Archives can only be uploaded via HTTP/HTTPS.
- SMTP is NOT supported as an upload method for Performance Archives.
- If you do not have HTTPS access to support.netapp.com for uploading archives, please see KB How to use OneCollect to upload performance archives to NetApp Support.
- To verify HTTPS is being used, run the following command:
::> autosupport show -fields transport
- Run the '
system node autosupport invoke-performance-archive
' sub-command with the following options:
-start-date <"MM/DD/YYYY HH:MM:SS">
-duration <[ h][ m][ s]> (or -end-date)
-node *
-case-number
- Note:
- It is important to note that the maximum duration for any single collection is 6 hours and the recommended sample period is 4 hours.
- Example:
- Using an external monitoring tool (example: OnCommand Performance Manager), a change in the latency trend for a cluster was identified between 6:00 AM and noon on 1 November 2014.
- According to the tool, an increase in latency occurred at 8:00 AM and lasted approximately 4 hours.
- As the best data set covers the period before the issue is seen as well as the transition to when the latency trend changes, data should be collected from 6:00 AM to 10:00 AM.
- This would provide a 2 hour sample of data before the issue was identified (6:00 AM to 8:00 AM) and a 2 hour period (8:00 AM to 10:00 AM) when the issue was occurring.
- On reaching out to Customer Support, this issue was assigned case number
2008123456
:system node autosupport invoke-performance-archive -start-date "11/01/2020 06:00:00" -duration 4h -case-number 2008123456 -node *
- The start date should be in quotes, and follow the "MM/DD/YYYY" format.
- For example, September 1, 2019 would be "09/01/2019".
- Case number must be included, and collection must go from all nodes.
- Example:
- To view the progress of the Performance Archive upload you can use the following commands:
::> autosupport history show-upload-details -node <node name> -seq-num <seq-num>
- Why might I still need to run Perfstat?
- In order to ensure that issues are resolved as expediently as possible, it may be necessary to continue to collect Perfstat as well as the clustered Data ONTAP Performance Archive content simultaneously.
- A Performance Archive is a data-dense binary file that requires post-processing to properly consume the content.
- Certain counters may not be included in the Archive, in early versions of ONTAP 9, and are only available via the CLI or via perfstat.
- How can a user look at the content within a Performance Archive?
- Active IQ Unified Manager and OnCommand Unified Manager utilize the underlying data set that is stored within a Performance Archive.
- How can I validate that a Performance Archive has been uploaded properly?
- The command
system autosupport history show
will give the status of the Performance Archive AutoSupport. - It should show
sent-successful
on completion of the transmission. - Additionally, AutoSupport messages will appear on your Active IQ page.
- Search by your serial number to verify if the Performance Archive has completed successfully and been processed by NetApp's systems.
- The command
- A Performance Archive failed to upload. How do I resolve the failure?
Additional Information
additionalInformation_text
