Panic occurs by Node watchdog for MGWD process
Applies to
- ONTAP 9.5
Issue
- System reboots after the following software panic:
Example:
Process mgwd unresponsive for 840 seconds in process nodewatchdog on release 9.5 (C)
- The panic happens after reporting the below errors in EMS.
Example:[Node_name: wafl_exempt05: wafl.memory.statusVeryLowMemory:alert]: WAFL is running very low on memory, with 590MB remaining.
[Node_name: wafl_exempt00: wafl.memory.status:info]: 8638MB of memory is currently available for the WAFL file system.
