Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
NetApp Knowledge Base
Packet loss causing slowness and latency outside of ONTAP
1,926
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
nas
Last Updated:
Applies to
ONTAP 9
Issue
  • When inspecting a packet trace, packet loss is usually identified by multiple duplicate acknowledgements (at least #1, #2, and #3) along with retransmissions
  • Application slowness and high i/o wait times are seen or users have performance issues or latency
  • If the loss is severe enough, the connection may be disconnected
  • ONTAP latency is low and utilization of CPU and disk is lower than normal or expected
  • Packet loss may be increasing in ONTAP 9.5 or higher
Example: Increasing Rexmit and OOORcv columns for 10.1.2.9 from netstat -anceWCT
node 1:
Proto Recv-Q Send-Q Rexmit OOORcv  0-win Local Address                                 Foreign Address
=-=-=-=-=-=Sat Aug 13 2022, 23:16:01 -0400   BSD-NETSTAT-ANCEWCT 6 lines
tcp4       0      0 6198853 112463181      0 10.1.2.3.3260                              10.1.2.9.47254
=-=-=-=-=-=Sat Aug 20 2022, 23:26:09 -0400   BSD-NETSTAT-ANCEWCT 6 lines
tcp4       0      0 1304064 57461127      0 10.1.2.3.3260                              10.1.2.9.21933
node 2:
=-=-=-=-=-=Sat Aug 13 2022, 23:15:27 -0400   BSD-NETSTAT-ANCEWCT 6 lines
tcp4       0     48 5768522 3592331      0 10.40.40.27.3260                              10.1.2.9.43744
=-=-=-=-=-=Sat Aug 20 2022, 23:25:03 -0400   BSD-NETSTAT-ANCEWCT 6 lines
tcp4       0     48 1366568 11947331      0 10.40.40.27.3260                              10.1.2.9.43425
New to NetApp?
Scan to view the article on your device
