Coming soon...New Support-Specific categorization of Knowledge Articles in the NetApp Knowledge Base site to improve navigation, searchability and your self-service journey.
ONTAP upgrade from 8.3 to 9.1 gets aborted due to BCOMD offline
246
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
Issue
ONTAP upgrade from 8.3 to 9.1 aborted due to BCOMD offline.
Error sample:
::*> system node upgrade-revert show
Node: node01                                        Status: aborted
Status Message: The upgrade aborted. Contact support personnel for the upgrade repair procedure.
Vers Phase      Status   Upgrade Phase Status Message
420  pre-root   applied  No upgrade is required for this phase.
420  pre-apps   applied  Upgrade successful.
420  post-apps  applied  Upgrade successful.
510  pre-root   applied  No upgrade is required for this phase.
510  pre-apps   applied  Upgrade successful.
510  post-apps  aborted  Node "node01" on ring "Bcom" is offline.
Node         Vers Phase     ID  Proc   Status     Description
node01      500 post-apps 504 mgwd   applied    FlexCache UpgradeRevert App Task For 9.0
node01      500 post-apps 505 mgwd   applied    Predefined_roles_update_upgrade
node01      500 post-apps 506 mgwd   applied    Predefined_roles_update_revert
node01      500 post-apps 508 mgwd   applied    Upgrade_Revert of 9.0.0 FPolicy Features
node01      500 post-apps 510 mgwd   applied    Session Limits Upgrade/Revert Task
node01      500 post-apps 514 mgwd   applied    Web Services 9.0.0 RDB Upgrade/Revert Task
node01      500 post-apps 515 mgwd   applied    Web Services 9.0.0 Upgrade/Revert Task
node01      500 post-apps 516 mgwd   applied    Revert Audit records
node01      500 post-apps 519 mgwd   applied    Autobalancer_support
node01      500 post-apps 520 mgwd   applied    InfiniteVol Revert Task
node01      500 post-apps 521 mgwd   applied    InfiniteVol Upgrade Task
node01      500 post-apps 522 mgwd   applied    Upgarde and Revert task for LDAP
node01      500 post-apps 523 bcomd  aborted    LUN Map LGID Upgrade/Revert
New to NetApp?
Scan to view the article on your device
