NetApp Knowledge Base
ONTAP EMS reports cifs.replay.failure for multiple modules
607
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
nas
Last Updated:
Applies to
ONTAP 9
Issue
  • The following messages are seen in the EMS log
Sun May 09 05:19:56 -0600 [node-01: mgwd: cifs.replay.failure:alert]: Failed to replay configuration for cifs-nblade module.
Sun May 09 05:25:41 -0600 [node-01: mgwd: cifs.replay.failure:alert]: Failed to replay configuration for http module.
Sun May 09 05:25:41 -0600 [node-01: mgwd: cifs.replay.failure:alert]: Failed to replay configuration for object-server module.
Sun May 09 05:25:42 -0600 [node-01: mgwd: cifs.replay.failure:alert]: Failed to replay configuration for common-proto module.
Sun May 09 05:25:42 -0600 [node-01: mgwd: cifs.replay.failure:alert]: Failed to replay configuration for secd module.
  • May also see aggregates and volumes showing as unknown or - on the node experiencing the issue
New to NetApp?
