We are redesigning the NetApp Knowledge Base site to make it easier to use and navigate. The new and improved site will be available the first week of October. Check out our video or read this KB article to know more about changes you’ll see on the site.
ONTAP AutoSupport using HTTPS fails validation when the Certificate is removed
369
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9.2 and later
  • AutoSupport
  • Transport HTTPS
Issue
AutoSupports are no longer succeeding after removing some certificates from the truststore
::>autosupport check show-details
Node: cluster1-01
Category: http-https
          Component: http-put-destination
             Status: failed
             Detail: HTTP/S PUT connectivity check failed for destination:
                     https://support.netapp.com/put/AsupPut/. Error: Peer
                     certificate can not be authenticated with given
                     Certificate Authority certificates.
  Corrective Action: Certificate issue. Please make sure you have the correct
                     Root Certificate installed
          Component: http-post-destination
             Status: failed
             Detail: HTTP/S POST connectivity check failed for destination:
                     https://support.netapp.com/asupprod/post/1.0/postAsup.
                     Error: Peer certificate can not be authenticated with
                     given Certificate Authority certificates.
Category: on-demand
          Component: ondemand-server
             Status: failed
             Detail: AutoSupport OnDemand connectivity check failed for
                     destination:
                     https://support.netapp.com/aods/asupmessage. Error: Peer
Verify if the following certificate is missing
::> truststore show -common-name AAACertificateServices
  (security certificate truststore show)
Vserver    Serial Number   Common Name                            Type
cluster1   01              AAACertificateServices                 server-ca
    Certificate Authority: AAA Certificate Services
          Expiration Date: Sun Dec 31 23:59:59 2028
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
  • Was this article helpful?
