NetApp Knowledge Base
ONTAP AutoSupport (Transport SMTP) resolution guide
296
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9
  • AutoSupport
  • Transport SMTP
Follow this guide to help you locate the proper solution to your question or issue.
For a smoother experience, run the following command to gather your Nodes configuration
Verify your current configuration
::>autosupport show -node <node name> -instance
Node: cluster-01
State: enable
SMTP Mail Hosts: mailhost
From Address: admin@email.com
List of To Addresses: address1@email.com,address2@email.com
List of Noteto Addresses: -
List of Partner Addresses: -
Send AutoSupport Messages to Vendor Support: enable
Protocol to Contact Support: SMTP
Support Proxy URL:
Verify Connectivity is good
cluster1::> system node autosupport check show -node node2
                            On Demand
Node             HTTP/HTTPS Server     SMTP       Configuration
node2            ok         ok         ok         ok
Connectivity fails
  • If connectivity fails, you must check connections to the Mailhost.
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
