Node is stuck "in-progress" during ONTAP cluster upgrade
Applies to
ONTAP 9
Issue
- Cluster upgrade is started and successfully completes on all but 2 nodes (a single HA pair)
cluster image show-update-progress
shows a single node "in-progress"- On checking, that node is successfully upgraded with the correct ONTAP version and post upgrade tasks complete, however the cluster upgrade is not continuing to last 2 nodes in cluster
- Rebooting the master node running the cluster upgrade doesn't help
