Coming soon...New Support-Specific categorization of Knowledge Articles in the NetApp Knowledge Base site to improve navigation, searchability and your self-service journey.
Node goes down with panic "giveback or arl hung in replication_engine while doing SENDHOME_DOING_PRECOMMIT in SK process"
83
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9
  • FAS/AFF
Issue
Node goes down reporting the following software panic string followed by a coredump:
PANIC: giveback or arl hung in replication_engine while doing SENDHOME_DOING_PRECOMMIT in SK process sendhome_hang_detector
on release 9.8P12 (C) on Sun  Thu May 12 20:07:27 EDT 2022
compile flags: x86_64.optimize
HA: current time (in sk_msecs) 2403764 (in sk_cycles) 6227546366396
DUMPCORE: START
Dumping to disks: 0d.00.15P2
coredump: Using block 461193217 instead of block 461193216 as the sparecore abort block
DUMPCORE: END -- coredump written
coredump: compression ms 315347 compressions 209628 bytes in 566686916608 bytes out 53045401980 ratio 1068%
comp BW 1713MB/s
coredump: write ms 51529 write count 15376 write bytes 53047083008 write BW 89MB/s
coredump: total ms 570912 chunks of all zeroes 23715
New to NetApp?
Scan to view the article on your device
