NetApp Knowledge Base
No compression savings in ONTAP 9.8P1 or later
3,788
Visibility:
Votes:
2
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9.8 or later
  • Temperature Sensitive Storage Efficiency (TSSE)
Issue
  • All volumes with auto-adaptive inline compression enabled display 0B compression in ONTAP 9.8:
::*> aggr show-efficiency -aggregate !*root,!*snaplock -fields volume-compression-saved
aggregate              volume-compression-saved
aggr1                  0B
aggr2                  0B
  • Volume shows deduplication savings, but no space saved by compression:
::*> volume show -volume vol* -fields dedupe-space-saved,dedupe-space-saved-percent,compression-space-saved,compression-space-saved-percent
vserver  volume               dedupe-space-saved dedupe-space-saved-percent compression-space-saved compression-space-saved-percent
svm1     vol3                 111.6GB            7%                         0B                      0%
svm1     vol4                 184.2GB            10%                        0B                      0%
  • Attempt to run compression manually fails with error:
::*> volume efficiency start -vserver svm1 -volume vol1 -dedupe true -compression true -compaction true -scan-old-data true
Warning: This operation scans all of the data in volume "vol1" of Vserver "svm1". It might take a significant time, and degrade performance during that time.
Do you want to continue? {y|n}: y
Error: command failed: Failed to start efficiency on volume "vol1" of Vserver "svm1": "-compression" option is not supported on
                                     auto-adaptive compression enabled volumes.
New to NetApp?
Scan to view the article on your device
