Can an existing NVE volume be encrypted?
Applies to
ONTAP 9
Answer
- Beginning with ONTAP 9.3, you can use the
volume encryption conversion start
command to enable encryption of an existing volume "in place," without having to move the volume to a different location. - In ONTAP 9.2 and earlier, you must use the
volume move start
command to enable encryption by moving an existing volume.
Note: A volume move does not disrupt client access during the move.
Additional Information
additionalInformation_text
