NFS mount hung after attempting a READ, WRITE or other operation with a large payload
Applies to
- ONTAP 9
- NFS
Issue
- NFS export is mounted without any issues
- Small READ and WRITE operations succeed
- Large READ and WRITE operations can cause the mount to hang
- Other operations which are not small enough to fit within a standard MTU (1500 or less) can also cause a hang
- READDIRs for some directories can return a large result, possibly exceeding the actual MTU of the network path, and causing a hang
