NetApp Knowledge Base
NFS UDP traffic intermittently drops after upgrade to ONTAP 9.2 or newer
778
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
network
Last Updated:
Applies to
  • ONTAP 9.2 and later
  • NFSv3 over UDP
  • All non TCP traffic
  • ICMP
Issue
  • Mostly the issue is found after ONTAP is upgraded to 9.2 or later, the filer does not reply to every ICMP (ping) request even if it can be found in a packet trace.
  • This is occurring on every interface on the cluster and even on e0M interface.
  • A strange behavior could be related to multiple LIFs on the same port not responding at different times.
  • This issue is affecting the NFS data transfer also if UDP is used as a transport layer causing a huge delay
      This can be confirmed by following simple test:
        Situation1# Mounted with UDP
[root@centos-04 /]# mount -t nfs -o vers=3,proto=udp 10.128.242.45:/vol1_svm2  /mnt/vol1_svm2_ontap93
[root@centos-04 /]# cd  /mnt/vol1_svm2_ontap93
[root@centos-04 vol1_svm2_ontap93]# dd if=/dev/zero of=./test bs=4096 count=10000
10000 0 records in
10000 0 records out
40960000 bytes (41 MB) copied, 37.0209 s, 1.1 MB/s  <<<
         Situation2# Mounted with TCP
[root@centos-04 vol1_svm2_ontap93]# cd /
[root@centos-04 /]# umount /mnt/vol1_svm2_ontap93
[root@centos-04 /]# mount -t nfs -o vers=3,proto=tcp 10.128.242.45:/vol1_svm2 /mnt/vol1_svm2_ontap93
10000 0 records in
10000 0 records out
40960000 bytes (41 MB) copied, 0.240958 s, 170 MB/s <<<
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
