NetApp Knowledge Base
NFS TCP mounts fail with"portmap query retrying: RPC: Timed out" using Flexgroups in ONTAP
4,583
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
nfs
Last Updated:
Applies to
  • ONTAP 9.7P2 CLUSTER-MODE
  • Flexgroup
Issue
  • NFS v3 and v4 mounts that use TCP fails/hangs:
[root@rhel_admin tmp]# mount -v  ap01s05nas01.sce05.ap01.arm.com:/net05_homes/net05_homes /tmp/net05_homes/
mount.nfs: timeout set for Tue Jun  9 19:18:48 2020
mount.nfs: trying text-based options 'vers=4.1,addr=10.xx.yy.10,clientaddr=10.xx.yy.39'
^C
[root@rhel_admin /]# mount -v -o vers=3,sec=sys netapp123.netapp.com:/net05_home/net05_home /tmp/net05_home/
mount.nfs: timeout set for Tue Jun 9 17:48:46 2020
mount.nfs: trying text-based options 'vers=3,sec=sys,addr=10.xx.yy.10'
mount.nfs: prog 100003, trying vers=3, prot=6
mount.nfs: portmap query retrying: RPC: Timed out
mount.nfs: prog 100003, trying vers=3, prot=17
mount.nfs: trying 10.xx.yy.10 prog 100003 vers 3 prot UDP port 2049
mount.nfs: prog 100005, trying vers=3, prot=17
mount.nfs: trying 10.xx.yy.10 prog 100005 vers 3 prot UDP port 635
[root@rhel_admin /]# ping netapp123.netapp.com
PING netapp123.netapp.com (10.xx.yy.10) 56(84) bytes of data.
64 bytes from netapp123.netapp.com (10.xx.yy.10): icmp_seq=1 ttl=62 time=0.116 ms
64 bytes from netapp123.netapp.com (10.xx.yy.10): icmp_seq=2 ttl=62 time=0.160 ms
64 bytes from netapp123.netapp.com (10.xx.yy.10): icmp_seq=3 ttl=62 time=0.151 ms
64 bytes from netapp123.netapp.com (10.xx.yy.10): icmp_seq=4 ttl=62 time=0.147 ms
^C
--- netapp123.netapp.com ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3000ms
rtt min/avg/max/mdev = 0.116/0.143/0.160/0.020 ms
  • "rpcinfo -p" fails with error that portmapper is timing out :
[root@rhel_admin /]# rpcinfo -p 10.xx.yy.10
rpcinfo: can't contact portmapper: RPC: Timed out
  • NFS v3 mounts that use UDP are not affected
  • When LIF is migrated to other nodes the TCP mounts work fine.
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
