Multipart S3 upload not implemented
Applies to
ONTAP 9.9.1
Issue
Uploading a big file (bigger than 100MB) is failing with an error:
Example:
$ aws s3 cp --endpoint-url http://ip/path_to_endpoint test.pdf s3://bucket_name
upload failed: ./Test.pdf to s3://bucket_name/test.pdf An error occurred (NotImplemented) when calling the CreateMultipartUpload operation: The s3 command you requested is not implemented.
