NetApp Knowledge Base
MGWD panics and restarts on a regular basis; cluster node may panic regularly
1,112
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
network
Last Updated:
Applies to
  • ONTAP versions prior to 9.3P13
  • SNMPv3 monitoring
  • CHMODE
Issue
MGWD reports a crash and restart in the log file. A core file for MGWD is also generated.
Mon Jan 21 17:00:25 CST [node1: mgwd: kern.vm.mmap.return:notice]: mmap(2) by mgwd (pid 90982) for size 2097152 failed: VMEM limit exceeded, limit 4294967296, error 12.
Mon Jan 21 17:00:25 CST [node1: mgwd: ucore.panicString:error]: 'mgwd: Received SIGABRT (Signal 6) at RIP 0x81ab66bba (pid 90982, uid 0, timestamp 1548111625).'
Mon Jan 21 17:00:50 CST [node 1: spmd: spm.mgwd.process.exit:EMERGENCY]: Management Gateway (mgwd) subsystem with ID 90982 exited as a result of signal signal 6. The subsystem will attempt to restart.
Mon Jan 21 17:01:19 CST [node 1: rastrace_dump: rastrace.dump.saved:debug]: A RAS trace dump for module EVMGR instance 0 was stored in /etc/log/rastrace/EVMGR_0_20190121_17:01:19:946051.dmp.
Mon Jan 21 17:01:50 CST [node 1: coredump_manager: ems.engine.suppressed:debug]: Event 'coredump.findcore.nocore' suppressed 1 times in last 146504 seconds.
Mon Jan 21 17:01:50 CST [node 1: coredump_manager: coredump.findcore.nocore:debug]: No unsaved cores could be found
The node may also panic and generate a core dump.
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
