NetApp Knowledge Base
Is there a way to configure an Apache webserver for being able to upload configuration backups via http from an ONTAP system?
290
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
Ontap 9
Ubuntu 20.04.4 LTS
Answer
If you configure Apache with the WebDAV module, it will work properly as a destination for uploading system configuration backup data.
Additional Information
This external page's instructions were used successfully in configuring Apache to upload configuration backup data via HTTP from Ontap 9.
When using the system configuration backup upload the following applies:
  • If HTTP is configured at the webserver then an HTTP PUT operation is used to send the file to webserver
  • If HTTPS is configured at the webserver then an HTTP POST operation is used to send the file to webserver
Scan to view the article on your device
