Is it possible to specify the unit of quota report command output?
Applies to
- ONTAP 9
Answer
quota report
command output can set by set -units <Unit>
command.set
command effect to all command output, not only quota report
command.- Check the setting of current units of size by executing the
set
command. - Check the specifiable values by executing the
set -
units
command. - Set the unit by executing the
set -units <Unit>
command. - Confirm the change in the setting of current units of size by executing the
set -
units
command. - Confirm the change the units by the same command.
Example:
cluster2::*> quota report
Vserver: svm21
----Disk---- ----Files----- Quota
Volume Tree Type ID Used Limit Used Limit Specifier
vol1 qtree1 tree 1 4KB 550MB 5 - qtree1
cluster2::*> set
User Name: admin
Profile Name: admin
Privilege Level: diagnostic
Confirmation Messages: on
Show All Fields: false
Show Field Separator:
Data Units: auto
Pagination Rows: 32
Default Vserver:
Default Node:
Stop On Error: false
Prompt Timestamp:
cluster2::*> set -units ?
auto Auto-scale data size for human readable output
raw Bytes without unit designation
B Bytes
KB Kilobytes
MB Megabytes
GB Gigabytes
TB Terabytes
PB Petabytes
cluster2::*> set -unit MB
cluster2::*> set
User Name: admin
Profile Name: admin
Data Units: MB
Pagination Rows: 32
Default Vserver:
Default Node:
Prompt Timestamp:
Vserver: svm21
vol1 qtree1 tree 1 0MB 550MB 4 - qtree1
Additional Information
- The details of
set
command are described at set command manual page.
