Is it possible to get FlexGroup volume size, availablility and usage via SNMP?
Applies to
- ONTAP 9
- NetApp ONTAP FlexGroup (FlexGroup)
Answer
- It is not possible to get the value of a FlexGroup volume as a whole.
- It is possible to get per each volume that constitutes a FlexGroup.
- Sum the values of all the volumes that constitute a FlexGroup.
- Check the OID below for the value of each volume.
df64AvailKBytes snmp.1.3.6.1.4.1.789.1.5.4.1.31.1
df64TotalKBytes snmp.1.3.6.1.4.1.789.1.5.4.1.29.1
df64UsedKBytes snmp.1.3.6.1.4.1.789.1.5.4.1.30.1
Additional Information
additionalInformation_text
