NetApp wins prestigious Coveo Relevance Pinnacle Award. Learn more!
INSIGHT Japan :2023年 1月25日(水)ANAインターコンチネンタルホテル開催 へ参加・申込を行う
NetApp Knowledge Base
Is it possible to configure one port in UTA2 port pair to FC and other port to CNA mode?
616
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
nas
Last Updated:
Applies to
  • Product Model: AFF8020-R6
  • OS: Clustered Data ONTAP 8.3.1
  • Category 2: FAS
Answer
UTA2 ports can be configured as FC target/initiator or CNA (FCoE target/Ethernet) mode.
FC target mode is the default configuration for X1143A-R6 adapter ports. However, ports on this adapter can be configured as either 10-Gb Ethernet and FCoE ports or as 16-Gb FC ports.
Current configuration [Both the ports are configured as FC target mode by default]:
aff::*> ucadmin show -node aff-01 -adapter 0c
                 Node: aff-01
              Adapter: 0c
         Current Mode: fc
         Current Type: target
         Pending Mode: -
         Pending Type: -
Administrative Status: online
      Supported Modes: fc, cna
   Supported FC Types: initiator, target
  Supported CNA Types: target
aff::*> ucadmin show -node aff-01 -adapter 0d
                 Node: aff-01
              Adapter: 0d
         Current Mode: fc
         Pending Mode: -
         Pending Type: -
aff::> system node hardware unified-connect show
                       Current  Current    Pending  Pending    Admin
Node          Adapter  Mode     Type       Mode     Type       Status
aff-01        0c       fc       target     -        -          online
aff-01        0d       fc       target     -        -          online
2 entries were displayed.
Restriction on UTA2 Port pairs since they are connected to the same ASIC.
Port pairs connected to the same ASIC must be configured in the same mode. So both ports must be configured for the same mode and use the same SFP+ type.
Note: After changing the mode type of one port, the other port also gets changed.
Ensure the adapter must be offline to modify the mode:
aff::> network adapter modify -node aff-01 -adapter 0c -state down
aff::> system node hardware unified-connect modify -node aff-01 -adapter 0c -mode cna -type target -force true.Any changes will take effect after rebooting the system. Use the "system node reboot" command to reboot.
aff-01        0c       fc       target     cna      -          offline
aff-01        0d       fc       target     cna      -          offline
Therefore, it is not possible to configure one port in a UTA2 port pair as FC target/initiator and the other port in the CNA (FCoE target/Ethernet) mode.
Additional Information
additionalInformation_text
Scan to view the article on your device
